Check Autozone website for pricing in your area, not a plug, just a reference. The core for my truck is listed @ $17.99 as of 3 minutes ago. Based on the Weather Channel it's a little cold in your area right now, have you flushed your system? If you do you can carefully remove hoses from firewall and take a water hose and route water through one side and see the flow returning, would be a bit of a cold job right now. If it's plugged up you have your culprit. Otherwise, I'd look at the blend door, you didn't say year model, and make sure your heated air path is open when selected.
Tex
Tex
-11 is a might bit chilly.
I did not flush it after the rebuild. It was warm then.
Well, if your plenum door is cable-actuated, you could be getting no heat, because the cable is broken or crappy. Mine's really old, and it shifted around in the little bracket that holds it, so it wasnt where it was supposed to be and only gave me a little heat. It was also too crappy to open the door that far in the first place. If that sounds like the problem, just pop off your glovebox and move the cable to where it should be, or better yet, get a new, smooth-operating one. However, if your truck is one of the 92-96 models, the plenum door I'm pretty shure is vacuum-actuated, so you'll have to look for a leak or loose line or something.
Roger that. Neither is extermely expensive and you actually learn a good deal when doing replacements of this type. Fan's pretty easy, heater core a little more challenging. Again check your blend/plenum door. In an air system a restriction may actually cause a perceived pressure increase, much like when you pinch the end of a water hose, velocity increase, volume loss. If it's warm enough, after checking trhe door, I'd flush it anyway. Don't want to get crap in the new core.
Tex
