Low Range Light???
Old Dec 24, 2004 | 08:39 PM
ATC_250SX's Avatar
ATC_250SX
Low Range Light???
Hey guys, another question for someone to help me with,
I was just cleaning my truck, and I noticed in the cab, it has a light, It says " low range" im trying to figure out when its supposed to be on? is it for four wheel drive, or the transmission, I tried 4 low, nothing and 1st on the tranny, nothing, its got a bulb, but any idears????? Oh by the way 87 f-150, 351w, C6, 4X4. thanks guys, and Merry Christmas, or Happy Holidays, whatever you prefer.
Old Dec 24, 2004 | 08:51 PM
SuperHighOutput's Avatar
SuperHighOutput
The low range light should come on when the TRANSFER case is in low ranger. I am guessing that the sensor in the t-case is crusty... I have the same problem with my '95 but it is the 4x4 light that doesn't work.
Old Dec 24, 2004 | 08:53 PM
ATC_250SX's Avatar
ATC_250SX
hmm, is it one sensor or two?? I didnt think to look at it? maby i can fix it, although its not really a big deal, i mean its pretty abvous, the levers sticking right up in the middle of the floor.
Old Dec 24, 2004 | 09:37 PM
tex94F250's Avatar
tex94F250
Check your connections before anything else. That light probably sees less use than any other component light in your truck. Even a serious off-roader who drives his truck as an everyday vehicle will use 4 Low only when crawling. At worst the bulb is easy to change. Merry Christmas.
Tex
Old Dec 25, 2004 | 12:46 PM
ATC_250SX's Avatar
ATC_250SX
Ill take a look at that, ill check them all first then OHM out the circut, thanks guys and dont forget to have a MERRY CHRISTMAS,
