I have a '91 F-150 and have noticed that the a/c heater blower only has the high setting. When I turn it down to any of the lower settings the heater turns off and does not blow. It also makes a grinding noise when I start to use it on the high setting. Can anyone help? Do I need a new motor? Thanks
Welcome to the only family Ford Truck site, on the net. The members in this forum are very knowledgeable about these trucks; they will eagerly help you…with your question.
To insure a better understanding of how FTE operates, please read the guidelines, and the READ FIRST notes in each forum you choose to visit. I'm sure you'll find plenty of reading and information to surf though.
Enjoy FTE and Happy Holidays
87 XLT is right. If you only have the high setting, it's most likely your resistor. I just replaced my blower motor for the same reason. It would make this terrible squealing noise when I'd first turn it on but then would go away after about 30 seconds.
