Gear Question
Old Dec 23, 2004 | 07:07 PM
Ford-man22's Avatar
Ford-man22
Gear Question
I was wanting to know if you can pull the ring gear out without haveing to set the backlash or anything else? I want to put a limited slip in my front end. I can do it if I don't have to set anything up but I don't want to blow my front end up either. Thanks.
Old Dec 24, 2004 | 05:20 AM
ctfordguy's Avatar
ctfordguy
I was going to replace my diff in my 99. talked to a few mechanic friends and they suggested that I not do it my self unless I learned how to set the ring and pinion properly. Never did it because of the possibilty of chew up my rear end.
Old Dec 24, 2004 | 09:00 AM
WhëëlMå1's Avatar
WhëëlMå1
No, you cannot just pull and replace. With the addition of the LS unit, you would have to reshim and adjust the backlash again. This is one you need to leave to the professionals.
