Stalling out problem
Old Dec 23, 2004 | 05:13 PM
hamster's Avatar
hamster
Hi Guys,
Only my 2nd post and I haven't had any luck in the search mode on this subject...
Recently (last September) bought an 01 F250 SD w/7.3 Powerstroke, yesterday it started acting up while going down the road, under acceleration it was just like shutting the key off, it keeps going on it's own after a second or two, then it would be cutting in and out real spuratically (faster than you turn the key on and off) and then runs fine again. The service engine soon light comes on as soon as this happens, when you shut it off and restart it the light does not come on again until this problem happens again. I ran quite a few miles today with no problems until I let it set for about two hours after being warm. The water in fuel light does not come on when this happens, I changed the oil and filters about 400 miles ago, it has just over 41,000 miles on it and the previous tank of fuel I added some Power Service additive to it, the reccomended amount.
The tach is the only gauge that drops when this happens so I know it's not a power problem through the ignition, any ideas?? No hard start problems at all, however, since I put the Power Service in it, it does tend to labor a bit on a cold start when the ambient temp is below 25. This may have been the case beforehand, I haven't owned it long enough to be sure. Don't remember if if the temp got that low before I put this in. Sounds like a loose connection somewhere to me, but just thought I would ask here first to see if anyone else has had a problem similar to this before I spend the $100 at the dealership.
Never fails that something like this would happen around the holidays when all the shops will close early tomorow and we are supposed to get about 8" of snow tonight.
Don
Old Dec 23, 2004 | 05:34 PM
CAT_man_963's Avatar
CAT_man_963
Sounds like yet another CPS sensor issue to me. Do a search - you'll get hours of reading on the subject!!
Old Dec 24, 2004 | 09:54 AM
KC0FHM's Avatar
KC0FHM
Definitely Cam position sensor or CPS, However make sure your batt connectors are sound this problem will throw no computer codes and most of the ford mechanics I talked to about the symptoms have no Idea what you are talking about, a new one is a little pricey (cheaper from International) and very easy to replace if you've ever gotten your fingers greasy, just a bolt and a conector. My'96 would run about an hour then start to cut out then finally die completely, when cool would start and run for another hour
Old Dec 24, 2004 | 10:27 AM
Kwikkordead's Avatar
Kwikkordead
Yes. The CPS. Or the CMP (camp) sensor if you get it from International for a lot less than you would pay at Ford. Just ask for a CMP sensor for your (year of production) T444E engine.
Edit: I hope this link works, it's a locator for International truck dealers where you can go in to get the CMP sensor.
http://www.internationaldelivers.com...arts/index.asp
Old Dec 27, 2004 | 06:00 PM
hamster's Avatar
hamster
Thanks Guys, you were right about the CPS, I ended up taking it to the dealer to have the tranny flushed and the passenger seat belt latch replaced (per service bulletin) and that's what the diagnosis was. It idles smoother now and hopefully my milage will go back up a bit. I know cold weather plays a big role in milage but it's gotten down to the 12.5 range
If you need any info about recalls or service bulletins, check out this sight...
http://www.recall-warnings.com/auto-...ry-V.FORD.html
Don
cordonja
1997 - 2003 F150
Jan 13, 2017 04:13 PM
RedDevil460
Aug 12, 2016 06:07 AM
ExPACamper
49
Mar 31, 2015 03:52 PM
alfaista
Nov 9, 2014 07:43 AM
