Overfilled transfer case?
Old Dec 23, 2004 | 12:39 PM
CyberEagle's Avatar
CyberEagle
Question Overfilled transfer case?
The owners manual says the transfer case holds about 2 quarts of fluid. When I replaced the fluid in the transfer case for the first time, about a quart came out when I removed the FILL screw. The remaining two quarts were then drained when I removed the drain screw. So, my question is, is this normal to have the transfer case filled above the fill screw from the factory? Do I need to park nose down on a steep hill to add additional fluid to get the level up to factory standards ?
Anybody else have this same experience?
_______________________________
99 5.4L EB 4X4
Old Dec 23, 2004 | 07:55 PM
FTE Herman's Avatar
FTE Herman
Nope, in all likliehood... Wait I'll ask you to check this first. Was your trasmission about a quart low?
What happens is the seal between the transmission and transfer case fails and the tranny looses about a quart to the t-case.
Old Dec 23, 2004 | 11:29 PM
NoMo's Avatar
NoMo
Sometimes the transfer cases are "bench filled"... which means fluid was put in while the TC was lying on a bench. It's easy to over-fill them in that position. Being over-filled in this manner isn't common, but it's also not un-heard of.
However, you should definitely keep an eye on the transmission fluid level as hkiefus suggests.
Old Dec 24, 2004 | 12:04 PM
CyberEagle's Avatar
CyberEagle
over filled transfer case
I did not notice a significant change in the transmission fluid level. However I changed them both at the same time and I didn't pay particular attention to the level when I checked it prior to draining the transmission. I will keep an I on it now. Thanks for the info.
99 EB 5.4L 4x4
bulletpruf
Mar 10, 2020 01:09 AM
f250mtnbikr
May 15, 2015 10:26 AM
Jason T
Jan 6, 2015 02:04 PM
97ExpGuy
35
Jan 1, 2012 01:22 PM
AMG-SM
Aug 22, 2011 11:55 AM
