Sponsored by: Real Truck
truck leans
Old Dec 23, 2004 | 11:48 AM
04superduty's Avatar
04superduty
truck leans
I installed x springs on my truck and notice that it leans to the drivers side about 3/4-1". normally i wouldnt mind but it causes my plow to clean real good on the drivers side but the passengers side doesnt do so well. What is the best way to correct this? put the truck frame on jack stands and loosen up the springs letting them hang loose and then re tighten?
Old Dec 23, 2004 | 12:04 PM
DCSpecial's Avatar
DCSpecial
You want to torque the suspension with the weight of the vehicle on the it....so with the truck on the ground.
It could be that way if it was torqued with the weight off of the suspension or it could be the trac bar pulling the driver's side down.
When you swapped springs did you disconnect the trac bar?
Old Dec 23, 2004 | 12:31 PM
04superduty
nope DC, didnt even think about disconnecting the trac bar. so should i loosen the u bolts all up, then re torque them with the truck on the ground? on second though what exactly should i do. already screwed it up once.
Old Dec 23, 2004 | 12:32 PM
DCSpecial's Avatar
DCSpecial
When you originally tightened down everything was the truck on the ground?
Old Dec 23, 2004 | 12:33 PM
04superduty
nope, it was on jack stands.
Old Dec 23, 2004 | 12:38 PM
DCSpecial's Avatar
DCSpecial
Then I would loosen them up and torque everything to the proper setting with the truck on the ground.
Old Dec 23, 2004 | 12:41 PM
04superduty
ok cool thanks DC. what are the torque specs for the u bolts? cant remember where i saw it at.
Old Dec 23, 2004 | 12:45 PM
DCSpecial's Avatar
DCSpecial
Front u-bolts from what I remember are 99 ft/lbs......
Old Dec 23, 2004 | 12:50 PM
04superduty
again thanks DC, now its time to see if i can use my friends heated shop. its about 20 out now and im not doing this in my moms un heated garage.
Old Dec 23, 2004 | 03:25 PM
DCSpecial's Avatar
DCSpecial
It's warmer over there.....teens here, I think I heard something about -5* overnight .
Old Dec 23, 2004 | 07:14 PM
Rongold's Avatar
Rongold
Talking Lean
Hi,
Besides loosening and retorquing the U-Bolts, loosen all of the spring eye bolts and retorque them also. If the bushings are twisted, it could cause the truck to lean. I installed the "X" springs a couple of weeks ago, and my truck is no more than 1/4" different from side to side.
Torque figures are as follows:
U-Bolts 99 ft/lbs
Front eye bolt 203 ft/lbs
Rear eye bolt 185 ft/lbs
I hope you have strong arms---or a long torque wrench !!!
That rear shackle eye bolt is a bear to do while laying on the ground. You can do it on stands--just make sure that the stands are under the ends of the front axle, and the entire weight of the front of the truck is on the stands--Front wheels off the ground. If you are going to do it that way, be careful that you DO NOT pull the truck off of the jack stands while tightening the eye bolts.
RON
P.S. Ford does offer shims for a leaning truck, but they are only 3/8" thick and you can only use 1 per side, unless you can find a center bolt with a longer head. The part number of the shim is D7TZ-5742-A. All it is, is a 3/8" thick piece of steel with a hole in the center for the head of the center bolt.
Old Dec 23, 2004 | 07:35 PM
Bear Hunter's Avatar
Bear Hunter
Funny you should mention that. I had that same shim on my truck when it was stock...after getting the lift installed I found out that hole in the shim prevented the center bolt from maintaining postive contact on the other side. In other words the center bolt is only so long...so when you add the shim it takes away from the integrity of what the center bolt is supposed to do...because it is now effectively shorter. What I saw was barley any bolt left on the other side...which cant be good IMO.
Thoughts?
Old Dec 24, 2004 | 08:27 AM
ishmael2k's Avatar
ishmael2k
Smile
Check with a local body shop or off road facility. There are extensions available for the center bolts. We had to install a double set of camber shims on an older 2wd Superduty and needed the extensions to maintain a postive contact.
Old Dec 24, 2004 | 09:48 AM
Bear Hunter
...Didn't know that. I don't need it anymore...just found it odd that Ford wouldn't/doesn't address something like this with their own part.
Old Jan 1, 2005 | 03:52 PM
04superduty
update, i removed my front x springs to check them over and make sure nothing was wrong with them. i even switched them to remove any doubt that it was the springs. well my truck still leans about 1/2" which isnt that bad but still not the best.
when i re installed the springs i didnt torque the u bolts or shackes until the truck was off the jack stands. i even rocked the truck around to get everything to seat correctly. then i torqued the u bolts and shackles. i didnt mess with the trac bar at all. the tire pressure is correct all the way around so its not that. what else could it be?? aaaahhhh
would and an adjustable trac bar help?
