OK all you computer Pro's
Old Dec 23, 2004 | 08:16 AM
johare's Avatar
johare
I have a browser problem. On many web addresses (including FTE) when I go to the site I get an advertisement page first (sometimes it actually shows the site is unavailable) and then a second or two later the browser goes to the actual site. The URL has an advertisers web address before the actual URL I am planning to visit. If I hit back I go to the advertiser and must hit back again to actually go back toa site I wish to see.
I have run Adware, Spybot, an banner block and Norton Anti-virsus. No virsuses and all adware and spy files have been removed. I can't seem to get rid of this "ghost". Any ideas?
Old Dec 23, 2004 | 08:24 AM
Torque1st's Avatar
Torque1st
Posting Legend
Get Firefox and use it as a browser.
http://www.mozilla.org/
You can get a nice spelling checker plug-in here:
http://www.exchangecode.com/spellbound/
Old Dec 23, 2004 | 08:29 AM
snoman's Avatar
snoman
just a thought, have you looked under add/remove programs to see if there might be something loaded that would be causing that.
Old Dec 23, 2004 | 08:37 AM
johare's Avatar
johare
Yes I have and I have removed any programs that I did not recognize. Still does it!
Old Dec 23, 2004 | 09:09 AM
AeroPA's Avatar
AeroPA
I agree w/ Eric. Get the latest version of Firefox, and enable pop-up blocking. I haven't used IE since I picked up Firefox a while back. Works for me, no problems here.
Old Dec 23, 2004 | 09:25 AM
rangerxlt02's Avatar
rangerxlt02
Hey johare,
You may want to find a program called Hijack-This. It is for advanced users since it gives a list of all things found, and you must decide what to remove. Not for the faint of heart, can seriously cause problems if used incorrectly.
I have used it in the past when ad-aware and spybot couldn't find the problem.
Another thing I would suggest doing is make sure you have the latest set of definitions for your current spyware checking software. If you haven't done so, make sure to tell them to check for updates.
Good luck on your quest. If you can't get any of those to work, I'd also suggest stop using IE and switch to FireFox.
Merry Christmas
Old Dec 23, 2004 | 10:55 AM
byronbgs's Avatar
byronbgs
You could get the google tool bar as it has a popup blocker that is rated real good.
Old Dec 23, 2004 | 11:08 AM
pfogle's Avatar
pfogle
IE is THE WORST browser EVER. Even microsoft tells people not to use it. Get firefox and don't look back.
Old Dec 23, 2004 | 11:17 AM
MemOrex's Avatar
MemOrex
Delete all cookies, temporary files, objects, and try reseting the browser's settings. Privacy and Security should be at medium. Try re-installing it.
If all fails, I guess you can move on to FireFox, but I'm a lucky one and don't have problems with IE.
Old Dec 23, 2004 | 01:00 PM
250FordTruck's Avatar
250FordTruck
I know exactly what you are talking about. Mine has been doing the same thing for the last two days. The URL that shows up is something like WWW.ads234 then a whole bunch of stuff then the page you are trying to get. It was driving me nuts. A few minutes ago I checked my pop-up blocker and switched the setting from medium to high. Problem solved. I run IE with "pop-up blocker" which I downloaded from my ISP. I'm sure any of the better rated blockers will solve the problem.
Good luck!
Old Dec 23, 2004 | 01:06 PM
furball69's Avatar
furball69
Those things mess with your registry and can be difficult to remove unless done properly. Do a google search for the advertisers web domain name and you should fine instructions to remove it completely from your computer. Those things usually are installed by clicking 'yes' on a popup or other 'do you want to trust content form this site' windows. Remembe rthat some popups are actually gif/jpg images in the browser window and look like they have 'yes' 'no' 'cancel' buttons but the whole image is a link to malicious crap... always use the 'X' in the top right corner or Alt+F4 to close ANY popups.
Old Dec 23, 2004 | 01:10 PM
250FordTruck
Disregard my last reply. It only worked for a few clicks. I used Norton to scan for viruses and checked for updates on the MS website. I'm going to try some of the other ideas listed here now.
Old Dec 23, 2004 | 01:14 PM
johare's Avatar
johare
250FordTruck,
That is exactly what I have. If I find a solution I'll let you know and please do the same if you solve this problem.
Old Dec 23, 2004 | 01:42 PM
furball69's Avatar
furball69
here
When in doubt, use google.
Old Dec 23, 2004 | 02:02 PM
johare's Avatar
johare
furball69, you the man!!
This is the site I found from your Google link: http://reviews.cnet.com/5208-6122-0....ssageID=629721
I followed the instructions and it seemed to have done the trick! So far anyway! 250FordTruck, try this site and down load the uninstaller.
Thanks all!
