Weak Batt help
I got in my truck to come home (1992 F250 351) tonite and noticed the starter draged before it started. I shut it off and tried again same thing. I noticed my volt gauge was just in the "normal " area, and it useualy is at about 14-16 voltsor more then 1/2 in the normal. I drove home (the charge light was off.), shut her off,and tried to restart it her but the battery was too weak. I open the hood checked the bat terminals both weree a bit lose.
I am charging the battery, Im hoping it is not my Alternator?
I realy dont want to take it out tonite, what do you guys think ? If the charging light never came on( yes it works) could it be just a weak batery due to lose terminals?
One thing was when I had my A/c compresor changed I noticed that wneh I would put the heater a/c on the volt gauge would drop and thhen go bact to normal ARRRGH please help.
After that, you can turn on the headlights OR the A/C blower and the voltage should stay put. But if you turn on BOTH the voltage will dip. At least it does on my truck.
The third-gen alternator used in 1996 and beyond fixes several issues. It has at least double the low-speed output. It has 130 amps +/- of full RPM output. It has a proper post-style high-current output connector instead of the failure-prone parallel spade lugs.
You can upgrade from a second-gen to a third-gen fairly easily. This is a good upgrade to consider if you favor audio amplifiers, light bars, electric fans, or other power-hog accessories.
