stalling ranger
Old Feb 4, 2000 | 05:45 PM
Trail_Rider's Avatar
Trail_Rider
stalling ranger
Old Feb 15, 2000 | 09:35 PM
CantDrive55's Avatar
CantDrive55
stalling ranger
a friend of mine has a 90 ranger with a 2.9L with a five speed. He's having problems with the engine trying to stall out at highway speeds. We've changed the plugs and wires, and cleaned the throttle body, and bypass valve. it only does it after it is warmed up a bit. Also changed fuel filter. any ideas?
Old Feb 16, 2000 | 08:49 AM
Phillip Guidry's Avatar
Phillip Guidry
stalling ranger
You should change the cap & rotor also. Might also have the fuel pressure checked. Check all the vacuum lines & vacuum accesories. In the worst case, you may have a module & pick up beginning to fail.
Phillip
