is this normal?
Old Dec 22, 2004 | 02:44 PM
00F-350 stroker's Avatar
00F-350 stroker
is this normal?
It has been getting down in the single digits or below and my 00 7.3 gets really hard to start unless I plug it in . But starts fine when above 20 or so. Is this normal or should i bechecking my glow plugs and relays. This is my first winter with it so any info would be helpful. Thanks
Old Dec 22, 2004 | 05:43 PM
bilder12's Avatar
bilder12
try to cycle the plugs twice, before starting it. BUT single digits is pretty cold, i wud use the block heater at those temps.
Old Dec 22, 2004 | 06:10 PM
CAT_man_963's Avatar
CAT_man_963
When it's that cold - it'll really help to plug it in. I doubt anything is wrong with your glow plugs - I don't think it would start at all in those temps if there was. I don't know what oil you are running, but I just put Rotella synthetic 5w-40 in my truck for the winter - and it REALLY makes it start a lot easier in the cold!!
Old Dec 22, 2004 | 06:39 PM
00F-350 stroker
thanks for the reply. Im using 15 40 rotella. just wanted to make sure this is normal and that every thing is working ok.
Old Dec 22, 2004 | 06:54 PM
Ggg6's Avatar
Ggg6
Considering the oil you are using I would say it's normal. Not to say RotellaT is bad, just that 15-40 is a little thick at those temps.
