e-150 starter ?
Old Dec 21, 2004 | 07:42 PM
buddyone's Avatar
buddyone
e-150 starter ?
Would a bad starter in an econoline van cause the car not to idle for long periods, as in it stalls out, then can't restart. let it cool off and it will start again and the sall after a short time, then not start again til it cools down again.
Old Dec 21, 2004 | 09:24 PM
racinrob's Avatar
racinrob
you might wanna give more info. does the starter turn after it stalls? what year-engine combo?. any troubles before this? lose of power?
when the cat convertors go you'll stall when hot and only run a short while while cold. good luck. more info will help you get your answer.
