washer pump quit 02 explorer
Old Dec 21, 2004 | 07:18 PM
glgeek's Avatar
glgeek
greetings,
02 explorer-8cyl
washer pump quit. no sound of pump running when button is pushed.
i cannot find a listing for a fuse in the owners manual, is there one? relay?
where is the pump? in the fluid tank? if so, can the pump be replaced without removing the tank?
so many questions, i know. this is just a real bad time for this to go belly up.
any input would be appreciated.
thank you,
bruce
Old Dec 28, 2004 | 12:27 AM
Friday01's Avatar
Friday01
Good Question! My 99 Explorer just started giving me the same problem. Any imput would be appreciated.
Thank You,
Marty
Old Dec 28, 2004 | 01:54 PM
99Xplr's Avatar
99Xplr
I had a problem with my 99 my first winter with it... bought it used in May of 2003.... The bottle froze due to using cheap (non-antifreeze) washer fluid, when I went to use the washer, the fuse popped. I just looked it up online, and the fuse it a 7.5 amp fuse in position 12 (which is the third row down from the top on the right side) I eneded up putting a 10 amp fuse in its place and started using the RainX stuff (the orange stuff) from walmart. Have not had a problem with it since. Now the fuse position is for the 99, don't know if it is the same for the 2002, but it would be worth a look.
Old Dec 29, 2004 | 08:42 PM
glgeek's Avatar
glgeek
thanx for the replies.
i wish i could tell you why, but the darn thing started working again. i think that the observation about diluted washer fluid is probably correct. it got really cold here in minnesota last week, but is now back up in the 20's. i will probably top off my washer fluid before i get the oil changed from now on.
i never did find a fuse for the washer pump. i suppose it is combined with one of the wiper moters. the next time i feel like laying on the cold concrete, i'll go pull the wiper fuse and see what happens. who was it that decided that the fuse block should be mounted in a location that also requires a trip to the chiropractor? what where they they thinking?
thanks again,
bruce
