Sponsored by: Auxito
Tire pressure
Old Dec 21, 2004 | 03:49 PM
gmcnaught2000's Avatar
gmcnaught2000
Tire pressure
I just took a look at my tire pressure on all four tires. I haven't drove the truck today, so the tires were cold when I checked them. They are LT tires load C. For some reason I had the front tires at 50 psi and the rear tires at 40 psi. I did let air out of the front tires and now running 40 psi. Would that be the reason why my ride seemed like I had a rough ride? Any imput would be great. Thanks.
Old Dec 21, 2004 | 04:37 PM
MOOK929RR's Avatar
MOOK929RR
tire pressure definitely affects ride. 50 is a bit much if you are running stock tires, i think 36 is about right for fronts. you start going lower than that and it will feel a bit mushy and affect your gas mileage. When i drive home off the beach i have 15psi, now that is a crappy ride!
Old Dec 21, 2004 | 05:31 PM
gmcnaught2000
Thanks for the reply.
