frame measurments
Old Dec 21, 2004 | 03:41 PM
51frrdtrk's Avatar
51frrdtrk
frame measurments
I recently bought a 1994, F-250 that was hit on the passenger front. I need to check the frame befor i invest a lot of money.
Ford must make a book or data sheet with frame measurments. Does anyone know where they can be found,
I posted this question on the 87-96 F-series forum and got no replies.
Thanks....
Old Dec 22, 2004 | 10:00 AM
Howdy's Avatar
Howdy
Probably be best to make some calls around your area for a shop that specializes in frame work. I had a car straightened years ago on the best laser machine at the time, (I put it in a ditch and there was no doubt the frame was tweaked..). I think it cost $500 to fix it - one side was bent 5 inches lower than the other. It was a 64 Malibu SS convertible and I was a stupid kid..
It's not an exact science, because if it's bad it might not be worth the time or money to straighten it to factory specs. What they can do is balance things out so that it drives and tracks straight. If you're having a hard time seeing any damage visually or with a tape measure, it probably wouldn't cost much to have it checked out. You can do some diag. measurements and check rail to ground measurements from one side to the other. Plus, have someone turn the front wheels through the full range while you look under and check for loose rivits, (I've used a floor jack to check this, too). Check the impact area, if it didn't go beyond the sheet metal, a lot of times you can cross your fingers.
Old Dec 23, 2004 | 10:24 PM
hayfrmr318's Avatar
hayfrmr318
To have your frame just checked would cost around $150. The shop could then see exactly how bad the frame is and give you an exact quote on straightening it. Also, go to a Body Shop that does frames. They should be able to print you out frame specs that give you measurements to the exact Millimeter.
Old Dec 26, 2004 | 02:48 PM
austynn2001's Avatar
austynn2001
I'd say just measure a similar truck.
Old Dec 26, 2004 | 04:47 PM
51frrdtrk's Avatar
51frrdtrk
frame measurments
Thanks for the help..
It just so happens that i do have another 94 to check the damaged one against.
The damaged one went into a tree between the right front wheel and the frame. broke the tie rod coupling, bent the drag rod and broke off the core support mounting.
the truck only has 80,000 miles and is in good shape otherwise. I paid the towing bill and took ownership, was going to use some parts on my other 94, but this one looks better.
