I have a 94 Ranger, 3L, 5Spd that has a rough idle but it seems to run fine. My gas mileage is normal. I changed: plugs/wires/cap/rotor. I have also used STP fuel injector cleaner. Help my next stop is the dealer. please email me if you can help.
Thanks-
You can try cleaning the throttle body with a spray can of throttle plate cleaner which should be easily available locally to you.Follow the directions closely.Also,if you could remove the idle air bypass valve {will require the purchase of a new gasket for it}to clean this area as well while you're cleaning the throttle plates.Also check all the vacuum lines,connections,and accessories.Another possibility is a dirty EGR valve pintle that is not sealed shut while idling,this also requires removal and a gasket to clean.
Phillip
