My friend said it was a 460, but it looked way different than my 429. I was right to question this. Thanks for the info. I am using the motor. Does anyone know if these 400 motors are worth a dime?
alot of people swear by them.....ive never run one so i couldnt say.....are you positive that motor is original?? if its a 460 the oil dipstick will in the front on top.......
A 400 is not a Cleveland but it does belong in the same 335 series engine family.
Engine Identification:
351C/M/400 335 series: 8 bolts in rectangular valve covers. Timing chain housing is part of block. Thermostat housing on block. Exhaust bolt holes diagonal.
351M/400 335 series: intake is 10.7" wide the 351C is narrow.
351W/302/5.0L 6 bolts on trapezoidal valve covers. Thermostat housing on intake. Exhaust bolt holes horizontal.
429/460 385 series: 7 bolts in rectangular valve cover
352/360/390/427/428 FE series: Intake goes under valve covers.
There are other indicators but these may help.
There is more rating plate decoder information in the Read First: FAQ section at the top of the forum.
