Exhaust
Old Dec 20, 2004 | 10:52 PM
tolliewolly's Avatar
tolliewolly
Smile Exhaust
I was walking by this guys new Ford 6.0 today and when he started it up you could hear the turbo through the exhaust and it sounded so good! What did this guy do to his exhaust? and will it void warranty?
Old Dec 20, 2004 | 11:03 PM
jasfaa's Avatar
jasfaa
You can hear the turbo through a stock exhaust. You should have asked the guy what he did and who knows if it will void your warranty. It seems like it is a flip of a coin whether or not mod's will do anything. My dealership is mod friendly.
Old Dec 21, 2004 | 12:16 PM
tolliewolly
Well this was not stock at all. It sounded sooo good. What is the popular thing that people are doing to their 6.0's in order to get good sound and help fuel mileage?
Old Dec 21, 2004 | 12:30 PM
jasfaa's Avatar
jasfaa
I was teasing a little. Put a 4"exhaust from the Cat BAck with a different muffler than stock and you can hear the turbo much easier. Motorhaven sells them. If you really want to hear it change out the stock downpipe too. I don't think it does anything more than make the turbo whistle louder and I would not do the downpipe again if I had it to do over because it really did not seem to do anything other than make the turbo whine louder.
Old Dec 21, 2004 | 12:39 PM
toplevel's Avatar
toplevel
Smile
I'am using the MBRP 4 inch turbo back no cat It's a real head turner when comming down the street
Old Dec 21, 2004 | 05:27 PM
tolliewolly
What about doing straight pipes?
Old Dec 21, 2004 | 06:02 PM
jasfaa's Avatar
jasfaa
Straight pipes sounds good but I would leave the Cat. it really does not affect that much.
Old Dec 21, 2004 | 06:33 PM
tolliewolly
How do you like your monster exhaust? Did it help the fuel mileage? What all did you notice when you had it put on?
Old Dec 21, 2004 | 07:29 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
Be sure to check out MotorHaven for you exhasut...when you are ready to buy!
Old Dec 23, 2004 | 09:32 AM
ChiefGReid's Avatar
ChiefGReid
I put a 4" Silverline T-304 stainless steel exhaust on mine from www.dieselpowerproducts.com/exhaust. Mine is the single, CAT back system. Sounds awsome! Silverline is made by MBRP.
Old Dec 23, 2004 | 04:20 PM
durbi30's Avatar
durbi30
I put a 4 inch stainless turbo back system that eliminates the cat and I also did a k&n airfilter system at the same time. I noticed about a 50% decrease in turbo lag off the bottom.
Old Dec 23, 2004 | 07:46 PM
PAN's Avatar
PAN
I just installed an MRBP turbo back dual kit with cat eliminator pipe. I even cut the muffler off of the Y and put in straight 4 inch pipe. If you want loud and don't have neighbors like me you can get away with this.
Old Jan 31, 2005 | 01:01 AM
pullinbinder's Avatar
pullinbinder
Is there a trick to removing the stock 3" downpipe without cutting it or dis-assembling the truck? My '05 pipe doesn't want to come out no matter how I twist it.
Old Jan 31, 2005 | 07:39 AM
SBV45's Avatar
SBV45
This is out of the service manual. It is different for the Ex. If you want the lousy pictures with it, send me a PM with your email address with a space on each side of the @ .
Removal and Installation
Vehicles with automatic transmission
Remove the transmission fluid level indicator.
Remove the nut.
All vehicles
Loosen the clamp and disconnect the downpipe from the turbocharger.
Remove the nuts and the RH intake heat shield.
With the vehicle in NEUTRAL, position on a hoist. For additional information, refer to Section 100-02 .
Disconnect the wire loom from the crossmember.
Using a suitable high-lift transmission jack, support the transmission.
Remove the nuts.
Remove the nuts, bolts and the RH crossmember bracket.
Remove the RH crossmember nuts and bolts.
Remove the LH crossmember bolts.
Remove the crossmember.
Separate the transmission fluid filler tube and position aside.
4x4 vehicles
Remove the nut, washer and bolt.
Remove the nut, washer, bolt and the right front stabilizer bar link.
All vehicles
NOTE: Lower the transmission jack approximately 25 mm (1 in) to ease the removal of the downpipe.
Remove the nuts, bolts and the downpipe.
To install, reverse the removal procedure.
Otherwise us a sawzall.
Old Feb 2, 2005 | 01:10 AM
pullinbinder
Thanks, thats just what I needed. I didn't want to lower the trans. if I didn't have too, but guess I will.
