Hey. I've got a 1985 ford f 150 short bed. It's got a freshly rebuilt 300 6 with a 4 speed trany with a grany gear. Its a sweet truck in perfict shape. I Wanted to Know what it would take to convert it to a 4 wd.
- Can i keep my tranny and just swap the tail housting to a transfer case
- What will fit with the stering and suspunsion. What will i need to swap.
- will i have clearince issues with the motor.
WELCOME to the site, please read the Guidelines… Check out the list of forums and make sure you read the headings and Read First: notices in each forum. The members in this forum are very knowledgeable about these trucks, they will be by..... and help you with your question.
Good luck with your conversion. Enjoy FTE
I just did the suspension part of it and am awaiting a driveshaft before I swap the tranny but it should be a direct bolt over if you can find a donor truck. If I had found a truck instead of a Bronco, I would be done by now. ANyway, here is my input for the one I did a couple weeks ago...... https://www.ford-trucks.com/forums/s...43#post2222843
