Sponsored by: Real Truck
Transfer Case Question
Old Dec 20, 2004 | 05:08 PM
SMiller's Avatar
SMiller
What size socket does the drain\fill plugs take? Who all runs synthetics instead of regular mercon? Thanks guys! Going to change the fluid tommarow...
Old Dec 20, 2004 | 06:16 PM
warmdye's Avatar
warmdye
I believe the manual calls for synthetic. I use redline.
Old Dec 20, 2004 | 10:27 PM
SMiller's Avatar
SMiller
Manual says Mercon, nothing about syn. what size socket to get the plugs out?
Old Dec 21, 2004 | 10:30 AM
philips's Avatar
philips
I changed mine to Mobil 1 synthetic ATF. Have you crawled under to see what size socket? If I remember correctly, it does not take a socket. Philip.
Old Dec 21, 2004 | 10:40 AM
FortyFords's Avatar
FortyFords
3/8 extension or wratchet
Rich
I run Mobil 1 also in the 6 sp and the transercase
Old Dec 21, 2004 | 04:18 PM
SMiller's Avatar
SMiller
I got it changed today as well as the front and rear ends, all the fluids were kinda nasty, figure I will change them again within the next 8,000 miles, rear was salty having to use syn. each quart was $8+ and it took 4 quarts, sure would be nice to use cheap semi syn.
