Help on tire size
Old Dec 20, 2004 | 01:17 PM
Flooper's Avatar
Flooper
Help on tire size
I bought a used 92 F150 Supercab, long bed to pull a small horse trailer.
(302 engine, 3.55s, AOD, 2WD). It pulls the trailer just fine. But, because the thing is so long, it looks goofy with the tires that are on it. They just look too dang small for that long of a truck. I think the tires are P235 75 R15s. Is there any tire I can put on that will look bigger, that I won't have to reprogram the speedo, or lose anything in my pulling. Sorrry...not the brightest when it comes to tires.
mike
Old Dec 20, 2004 | 01:20 PM
Frank Lang's Avatar
Frank Lang
Might look goofy, but that's what Ford intended as tires for that truck. You can put on slightly larger tires--others will know better which ones are the best kind.
Frank.
Old Dec 20, 2004 | 01:28 PM
MustangGT221's Avatar
MustangGT221
Recalibrating the speedo is a necessity with changing tires for an accurate speedometer reading. You could move up to a 30/9.5/15 or a 31/10.5/15, the 31 would rub on the radius arm at full turn just a smidge, but it's not damaging. There is an article in the "tech articles" section of our website (link on the right) telling you how to recalibrate the speedo.
Old Dec 20, 2004 | 08:11 PM
jlarr's Avatar
jlarr
I have a '93 extended cab short box that I run 31x10.50R15s on & they don't rub. I have the stock Alcoa aluminum wheels. It definitely looks better & it actually corrected the speedometer inaccuracy I had with the P235/75R15s that came stock. I've run different brands of this size & none rub.
Old Dec 20, 2004 | 08:17 PM
Flooper's Avatar
Flooper
Thanks guys. That helps a lot. If I go with the sizes you suggest, how will it affect performance when pulling the horse trailer? I assume it will reduce my actual gear ratio...right? A lot? A little? Would I notice? Thanks again.
mike
Old Dec 20, 2004 | 08:39 PM
MustangGT221
If you stick with either a 30 or 31" diameter, it won't be enough to bother you since you have 3.55 gears. With 32's I felt a noticeable difference, but it still was not enough to bother me I still had pleanty of power to tow my boat and snowmobile trailer. I used to have a 302 and 3.55 gears.
My buddy has a 96 F-150 with the 300 and has gone between 31" and the stock 235s (pretty much a 29" tire), didn't notice much of a difference. It's not really much of a jump in tire size so it's ok.
Old Dec 20, 2004 | 09:51 PM
MemOrex's Avatar
MemOrex
I have 31/10.5/15 and they dont do any rubbing. And I agree, they look good with the stock rims; except that one of my rims lost the small red centerpiece....
Old Dec 20, 2004 | 10:09 PM
Saurian's Avatar
Saurian
I want 35's....anybody want to sponsor me for a lift? ^_^
33's are where you're pushing 3.55's, and when you get to 35" tires you want to head up to a 3.73 or preferrably a 4.10 I believe.
