General Automotive Discussion
Using DryGas for COLD weather Starting ??
Old Dec 20, 2004 | 11:44 AM
Katmandu's Avatar
Katmandu
Question Using DryGas for COLD weather Starting ??
The temperature this AM was 4 degrees outside when I first tried to start my 98 Explorer with 4.0 SOHC.
It would crank over just fine, but would NOT stay running. Finally, after several attempts at cranking it over, I held the throttle about 1/4 way opened and it stayed running.
My 98 only has 73k miles on it and has been very well maintained. Could the culprit be the gasoline ??
I've used DryGAS in the past with good results, so I put a can of it in my 98 this AM.
Old Dec 20, 2004 | 12:39 PM
CowboyBilly9Mile's Avatar
CowboyBilly9Mile
If the gas in your area is "oxygenated", you don't need to add fuel system dryer. The gas already has alcohol in it.
Old Dec 22, 2004 | 10:44 PM
Katmandu's Avatar
Katmandu
Question
Not sure. Would it be listed on the pumps somewhere ??
Old Dec 23, 2004 | 03:09 AM
CowboyBilly9Mile
It is in WA state. There is a sticker on the pump indicating that the gas is oxygenated and from what months they are doing it.
Old Dec 23, 2004 | 12:23 PM
rebocardo's Avatar
rebocardo
Most likely a border line sensor. My 1997 4.0 Ranger use to start in colder weather than that in Maine.
Old Dec 24, 2004 | 09:13 AM
Katmandu's Avatar
Katmandu
Question
It's not throwing any CEL codes (yet)......
Which Sensor would that be then ??
