General Automotive Discussion
Suggestions for Cold Weather
Old Dec 20, 2004 | 06:21 AM
Tom's Avatar
Tom
Wow, I got up this morning, and it was -19 degrees farenheit out. My truck has less than 14,000 miles, and it did not want to start. Even when it started, I got a loud whine for a few seconds, and I'm afraid to shut it off!
Does anyone have any good suggestions on things to do during really cold weather? Remote starter? Block heater? bigger battery?
Thanks!
Old Dec 20, 2004 | 06:38 AM
1991fseries's Avatar
1991fseries
then main things is a non water based battery that is in good condtion, and a block heater would help to keep your fluids from freezing those causes the biggest problems
Old Dec 20, 2004 | 07:22 AM
Marc150's Avatar
Marc150
Mine started, but took a long time to get the oil pressure up. Then it started idling rough, surging, had dark exhaust and ran like crap. After I let it idle for a while it smoothed out. I sure hope nothing was damaged!! Would one of those stick on block heaters be worth while, I'm not sure of any other kind of heaters.
Old Dec 24, 2004 | 05:10 PM
cyc79's Avatar
cyc79
Crazy001;block heaters work good.Two different vehicles I've had came equipped with dual block heaters(one on each side of block).These heat the block more evenly than a single but will sometimes trip the circuit breaker.Most vehicles here in Saskatchewan have one block heater.Another option is a circulating heater that mounts on your heater hose.
Old Dec 24, 2004 | 05:28 PM
Tranoham's Avatar
Tranoham
trouble light under hood .(50watt min) use your commen sense,were you place it
