Disconnecting emmission components
Old Dec 19, 2004 | 11:36 PM
lynxtrapper's Avatar
lynxtrapper
I have an 84 F-250 4X4 4 speed. I live in alaska and have no need for any of the junk I have on my tired old 351W. I want to help it breath better and If I pick up a few more MPG so much the better. What do I disconnect and then what do I do with the timing,carb,ect.? I have read that Ford retards timing by 4 degrees for emmission standards, so how do I compensate and What else do you guys recommend?
Old Dec 20, 2004 | 07:51 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
WELCOME to the site, please read the Guidelines… Check out the list of forums and make sure you read the headings and Read First: notices in each forum. The members in this forum are very knowledgeable about these trucks, they will be by..... and help you with your question.
Enjoy FTE
Old Dec 20, 2004 | 10:06 PM
Franklin2's Avatar
Franklin2
Unless you swap the carb out for a aftermarket non-emissions 4bbl, intake manifold to match, and dist(if your original does not have a vacuum connection) I would leave it alone.
