More CB help
Old Dec 20, 2004 | 01:39 PM
Pikachu's Avatar
Pikachu
Originally Posted by Fire Rooster
double checked it is rg-59 and they have pl-259 connectors
Yes, the male is a PL-259, the female on the radio is an SO-239. Both are 50 ohm connectors. Get rid of the 75 ohm RG-59 and get 50 ohm cable, or return it to where you got it and exchange it.
Old Dec 20, 2004 | 03:59 PM
Austin Charles's Avatar
Austin Charles
Originally Posted by long550
If you want to get a good signal go buy a 102" steelwhip with a ball mount and a spring. .
Now you will be talking
But watch out for those branches
Old Dec 20, 2004 | 04:16 PM
Fire Rooster's Avatar
Fire Rooster
Well I guess I will have to look into something else. I do not like the long whips etc. so I just bagged everything disassembled it and took it back. To much work for something I am only gonna use once in a while when on long road trips. Thanks everyone for the help.
Fire Rooster
Old Dec 20, 2004 | 05:47 PM
Austin Charles
What did you take back? the radio and everything? or just the antennas you bought?
If all you want it for are road trips, then why go to all the trouble just slap on a mag mount
Old Dec 20, 2004 | 07:41 PM
Austin Charles
Originally Posted by Pikachu
Yes there is a big difference between the two. RG-58 is 50 ohm cable, and RG-59 is 75 ohm. You'll never get the SWR adjusted properly. Use 50 ohm cable only. RG-8X or RG-8U would be a good choice for all of it.
you can't 'co-phase' antennas using the same impedance feed line. It isn't strictly necessary to use 75 ohm coax, though. If you can find it, 93 ohm coax would work too, or almost any impedance larger than 50 ohms. The bigger the difference is, the 'better' it will work, (sort of). You also have to consider the 'matching transformer's other characteristics, such as power handling ability (break down voltage, actually), how easy it is to find, what it costs, etc. Since 75 ohm coax is so common, it's the 'usual' choice.
PS - You are basically dealing with a parallel resistive circuit (handle impedance like you would resistace, in this case). If you analyze 'how' the different values affect the resulting resistance/impedance in a parallel circuit you'll see what I mean. To my knowledge, there are no commonly available coaxs that will result in 50 ohms, they all result in some impedance that is 'close', but not 'on the nose'. In most cases, 'close' is good enough...
Several times a year we get tech calls from installers who place dual antennas on their vehicle and run RG-58 or RG-8X from each antenna to a T-connector at the back of their radio only to find that the system "doesn't get out". You should not use 50 ohm coax on a ground plane dependent dual antenna installation ... it MUST be 72 ohm RG-59 type coax. These flawed installs can be misleading because SWR tests can show exceptionally low SWR, making the installer think that all is well. However, the impedence of the antenna system does not match the requirements of the radio and therefore, the output power of the radio is greatly reduced. In several tests, we found that a 4 watt radio would only generate 1.75 watts of output power which is the equivalent of having an SWR reading that exceeds 6.0:1. in addition, there is no need for a t-connector as a pair of 59 lines fit quite nicely into the rear of a PL-259 connector.
irishwrath
2004 - 2008 F150
Oct 23, 2010 09:59 AM
CousinCarl
Oct 11, 2008 12:37 AM
vanduzenguy
May 14, 2007 07:53 AM
Fire Rooster
30
Jan 19, 2005 09:29 PM
linux_author
2004 - 2008 F150
15
Oct 14, 2004 11:11 PM
