78 f-150 stalling
Old Dec 19, 2004 | 09:39 PM
buckford's Avatar
buckford
78 f-150 stalling
i have a 78 f-150 with a 300 I6, when going down the road it will quit like you turn off the key, i have tried 3 diffrent ignition moduels, what else will cause this, and when it stalls just turn the key and she'll fire right up, mainly does this when you hit a bump, and once in a while if you slam the hood. please help, its gettin cold. thanks ahead of time.
Old Dec 19, 2004 | 09:57 PM
SwOkcOffRoader's Avatar
SwOkcOffRoader
sounds like a bad wire some where, you can break out a testor and start going over all the ignition wires, and charging system wires, or you could simply "jiggle" the wires off of the alternator, coil, solenoid while its running and see if it has any effect, you say it happens when u hit a bump or shut the hood, that means a bad wire is getting shook and loosing contact for a while......thats how i found out the main positive off my alternator was bad....was kinda just dumb luck but it worked.....
