Battery Boosters
Old Dec 19, 2004 | 09:09 AM
vtdiesel's Avatar
vtdiesel
Battery Boosters
I have a 04 F350 diesel and am interested in getting a battery booster for it. I would like to know how big (amps) a pack I would need for the 6.0 L diesel.
Cold weather is a factor here in Vermont. Thanks for the help.
Old Dec 19, 2004 | 10:46 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
WELCOME to the site, please read the Guidelines… Check out the list of forums and make sure you read the headings and Read First: notices in each forum.
Be sure to check out the 6.0 Bible…..great reading
http://dan.prxy.org/Truck/6L_bible_html/html/TOC.html
http://www.backglass.org/duncan/ps60_manual/
…. In the upper right hand corner of your screen check this out PARTS SHOP for all your “trucking” needs
Must read
http://www.clubfte.com/users/monsta/SuperDutyFAQ.html
https://www.ford-trucks.com/forums/s...d.php?t=303583
Enjoy FTE
Old Dec 19, 2004 | 11:49 AM
Daryl Hunter's Avatar
Daryl Hunter
If they have different sizes available, I would buy the biggest one
Given that the PSD has two batteries in parallel, each of which deliver 650 to 750 CCA - that's 1300 to 1500 CCA, most of the common automotive jumpcharger thingys aren't going to make much of a dent with their 300 or so cranking amps.
But when you aren't completely dead and just need a bit of help, they might do the trick.
Old Dec 19, 2004 | 06:39 PM
huntercgr's Avatar
huntercgr
OK, here's a stoooopid question. Is a battery booster different than a battery charger? If not, I'm wondering why you'd need one with an '04.
