Sponsored by: Auxito
2000 F 150 Speedo problem
Old Dec 19, 2004 | 12:44 AM
Myfirstnewtruck's Avatar
Myfirstnewtruck
I have a 2000 4.6l 4x4 automatic. In the past month i have had problems with everything. My PCM was bad at 48000 miles and then i was also misfiring on # 4 i had to replace the plug and the Coil on Ignition thing. The speedo has been not reeding right it floats around like i can be crusin down the street in my neighborhood and it says that i am going 60. does anybody have any sugestions before i have to go and spend more money.
Old Dec 19, 2004 | 03:45 PM
triton_2002's Avatar
triton_2002
Check under the driver's side dash for any signs of water. There have been some problems with a water leak in the windshield that allows the fuse block and PCM to get wet and cause all kinds of electrical problems.
Old Dec 19, 2004 | 06:40 PM
Racerguy's Avatar
Racerguy
You might also have a problem with the Vehicle Speed Sensor which is in the extension housing at the back of the transfer case.
