Sponsored by: Auxito
2000 f150 supercab
Old Dec 18, 2004 | 11:49 PM
abwsjr's Avatar
abwsjr
2000 f150 supercab
when I go over a bump sometimes the #23 fuse blows and forces transmission into 2nd gear...if I replace fuse all is well until next time...my regular mechanic ran analysis which showed 13 different things which doesn't seem right...haven't taken it back to ford yet...anybody else have similar problem
Old Dec 19, 2004 | 09:42 PM
kspilkinton's Avatar
kspilkinton
First I've heard of that. I'd check all the wiring associated with fuse 23. Something may be shorting to the chassis ground when you hit the bumps. The other codes may be a result of the surge.
-Kerry
