Cold_Steel,
The connection sparks because the heater doesn't have an on-off switch and when you plug it it the electricity starts flowing immediately to the heater. It also tells you that it is working!
Good Luck!!!
Paul
Ditto. Spark means connection. I listen for about 5 seconds as well to make sure I can hear the coolant start to bubble at the heater, that way I know for sure it's all good.
well if the breaker didnt blow then its not a short
probably just current flow
a 2,500 watt heater will pull around 20 amps and that will make a good arc when you plug it in and out
You sure that is what these heaters pull for amps. A standard house outlet is only rated for a max of 15 amps.
