Shutdown timer
Old Dec 18, 2004 | 12:51 PM
FordxFour's Avatar
FordxFour
Question Shutdown timer
Got the HI-Idle switch installed today, like it just flip it and an instant 1200 rpm. Now is there a inexpensive way to put a timer in the harness so that upon flipping a switch the engine will run for a preset number of time after cutting off the ignition and removing the key? Any Idea's?
Old Dec 18, 2004 | 02:50 PM
Maxium4x4's Avatar
Maxium4x4
I missed something here, where did you get a high idle switch? My truck will high idle when first started on cold days, does this conflict?
Old Dec 18, 2004 | 02:59 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
I want one too....tell us more!~
Old Dec 18, 2004 | 03:09 PM
Maxium4x4's Avatar
Maxium4x4
Something for the Tech folder Tim, if we get an answer.....
Old Dec 18, 2004 | 03:33 PM
Workin4ALivin's Avatar
Workin4ALivin
I think he's talking about the high idle switch for the PTO option. One of our trucks where I work ramps up the rpm's when you flip on the PTO.
Old Dec 18, 2004 | 03:40 PM
FordxFour's Avatar
FordxFour
It is more or less a jumper under the dash from the white wire with the light blue stripe to the blue wire with the yellow stripe with a toggle switch in between. I read this on an earlier post about a month ago. I had to go back and find the post, so it would be nice if others could just go to the tech folder. If the truck is in park, just flip the switch an engine Idle's up to 1200 rpm. Its wintertime you know.
Old Dec 18, 2004 | 04:06 PM
FordxFour's Avatar
FordxFour
OK, I found the old thread but I dont know how to link it to this one.
Old Dec 18, 2004 | 04:15 PM
FordxFour's Avatar
FordxFour
https://www.ford-trucks.com/forums/s...ight=1200+rpm+
Old Dec 18, 2004 | 04:17 PM
FordxFour's Avatar
FordxFour
Sorry to drag out this thread but still learning to get links and replys in the same without messing up the link.
Old Dec 18, 2004 | 04:22 PM
mejer1's Avatar
mejer1
it was a post done by me1mcee. I did the mod also, it is a high idle switch. All 2003 and 2004 come pre wired from the factory for pto idle just not the hole in the trans. You just add toggle switch and hook up the two wires that are under dash and then truck will high idle at 1200 RPM. It is suppose to help with wet stacking when having to have extended idle times.
John
