Anyone use the engine block heater?
Old Dec 18, 2004 | 08:08 AM
Phil056's Avatar
Phil056
I'm curious if anyone uses (if they have it) their engine block heater?
I have one and never have used it. Is their much benefit to hooking it up and if so at what temperature do you guys determine when to use it.
Thanks!
Old Dec 18, 2004 | 09:45 AM
bubahyde's Avatar
bubahyde
I Installed one in my expy. I think it is great. During the winter months here in Michigan, I plug it in everynight. It keeps the warm up process to a minimum. I have heat 1-2 miles down the road. They say cold start up is hard on your vehicle, I feel the block heater can only help that issue by keeping your fluids a little warmer.
Old Dec 18, 2004 | 10:01 AM
ArcticDan's Avatar
ArcticDan
Engine Block Heater
I only use mine when the temperature drops below -20. In Anchorage, the city has been promoting using the heater when the temperature gets to +20 to help decrease air polution by cutting down on warm up time on the engine. In alot of cases I use the warm up feature of the auto-start which engages at -5 if it has been cold for several days in a row. That seems to help against cold soaking the battery, etc.
Dan
