A4LD Problem Help!
1) When I put it into reverse it feels like it engages but the truck won't move and the engine lugs.
2)When in neutral I can't roll the truck, it's like the brakes are on.
3)When in drive it goes forward but doesn't shift
4)When in low (1st) it barely creeps along with high revs and a lot of lugging.
5)If I put the transfer case in neutral it rolls easily.
6)If I put the shift lever in neutral and the engine is off I still can't roll the truck.
No codes stored for the trans.
Is this a major problem or could it be something electrical? Thanks for any help.
