90, E350 towing?
Old Dec 18, 2004 | 06:26 AM
trike1946's Avatar
trike1946
90, E350 towing?
Does anybody know the towing capacity of a 90, E350, diesel 7.3 non turbo, E4OD trans, and 3.55 rear? I wanted to tow about 6000 lbs about once a week to various locations. I went to Ford but they couldn't give me an answer. Thanks for your help.
Old Dec 18, 2004 | 02:23 PM
SoCalDesertRider's Avatar
SoCalDesertRider
6000 lbs will be fine with that one-ton van, diesel engine and 3.55 axle. You should be good up to at least 8000 lbs towing with that van.
Old Dec 18, 2004 | 05:40 PM
rclarke's Avatar
rclarke
According to the Ford towing guide you will be right at the towing capacity for a cargo van and a little over capacity with a club wagon (with seats). The non-turbo diesel is not rated to tow as much as the 7.5 gas.
Old Dec 18, 2004 | 06:05 PM
trike1946's Avatar
trike1946
Thanks for the replys. Where can I get a copy of the towing guide?
Old Dec 18, 2004 | 09:10 PM
Flash's Avatar
Flash
Out of the 1990 Ford Towing Guide, your rig, if it is a regular van, is rated at 6400 lbs, super van is rated at 6200 lbs. Changing rear gears to 4:10 will get ya another 2000 lbs towing capacity. Don't know where you can pick one of these guides up, mine comes from a friend that owns a Ford dealership. I was getting them and all of the dealer spec stuff every year but it got to be too much.
Old Dec 20, 2004 | 03:54 PM
trike1946's Avatar
trike1946
Would it help if I bought a weight distributing hitch? I checked the weight of the tractor and the trailer, and together they are 7000#. Or is the problem the engine and transmission? I just got a new trans with the heavy duty converter and upgrades.
