72 for an 88?
Old Dec 18, 2004 | 12:30 AM
djmac's Avatar
djmac
72 for an 88?
i am thinking of putting a used 72 460 in my truck to replace an 88 460. except for the fuel injected vs carb issues will everything else line up? like the starter, bellhousing ect?
Old Dec 18, 2004 | 09:22 PM
whd507's Avatar
whd507
yes. they are balanced differently, so you would need to retainn the balancer spacer, and flexplate from the 72. I have no idea if the D2AE heads will work with the FI setup. I suspect they wont, but I dunno. put a 71 timing chain set in it while its out.
Old Dec 18, 2004 | 09:30 PM
djmac's Avatar
djmac
why do you recommend a 71 timing set?
Old Dec 18, 2004 | 11:55 PM
whd507's Avatar
whd507
it advances the camshaft compared to the 88 or 72 set. better mileage, and more power.
Old Dec 19, 2004 | 01:09 AM
djmac's Avatar
djmac
thanks for your help!
Old Dec 19, 2004 | 02:31 PM
whd507's Avatar
whd507
68-71 chain set 429/460
its worked on every engine I've tried it on so far. when my 96 econoline 351w needs a timing chain, its getting one too...
