1978 - 1996 Big Bronco
96 Oil Pan
Old Dec 17, 2004 | 05:43 PM
wildboar's Avatar
wildboar
Cool 96 URGENT Oil Pan Question
The oil pan on my 96 w/302 is seeping oil through the rust. Can the Pan be removed/replaced without ripping the exhaust out or lifting the engine? My Haynes manual doesn't have a section on the pan replacement.
Pat
Old Dec 17, 2004 | 06:50 PM
Trucky18's Avatar
Trucky18
unfortunatly, no and no...i just did it a month ago. Here is the link to my write up, hope this helps
http://www.superford.org/registry/ve...=20906#content
Old Dec 19, 2004 | 02:37 PM
swenson's Avatar
swenson
Same thing happened to my 95 two years ago. Pretty pathetic that an oil pan rusts out, never had that happen before. Anyways, I had to have it done professionally because you do need to at least lift the motor a little to get the pan off due to the front crossmember. Cost me $450 bucks including the pan. Oh well. Good luck.
