2003 6.0 performance problems
Old Dec 17, 2004 | 03:52 PM
GREGOMAYER's Avatar
GREGOMAYER
I have a 2003 6.0 with 23,000 miles on it.
I have changed the oil & filter every 4,000 miles
The problems I have with it is the following
poor fuel mileage (11 mpg in flat Florida & not pulling a trailer)
exhaust smells soooooo bad it will gag you (bitter smelling fumes)
a definite "LAG" (turbo lag) when accellerating
an intermitten miss / rough idle
I have had it inb for service 3 times for the same concerns, the dealer said twice it was a bad sensor and the third time a bad ground.
I asked it the turbo could be causing the poor mileage and performance and the deal said the turbo is FINE.
How can I tell if a turbo is bad??
Why does the exhaust smell soo bad??
any ideas / thoughts are appreciated.
Old Dec 17, 2004 | 03:54 PM
Daryl Hunter's Avatar
Daryl Hunter
Hi GREGOMAYER,
WELCOME to the site, please read the Guidelines… Check out the list of forums and make sure you read the headings and Read First: notices in each forum.
Be sure to check out the 6.0 Bible…..great reading
http://dan.prxy.org/Truck/6L_bible_html/html/TOC.html
http://www.backglass.org/duncan/ps60_manual/
…. In the upper right hand corner of your screen check this out PARTS SHOP for all your “trucking” needs
Must read
http://www.clubfte.com/users/monsta/SuperDutyFAQ.html
https://www.ford-trucks.com/forums/s...d.php?t=303583
Enjoy FTE
I'm sure that one of our helpful regulars will be along in a bit
Old Dec 17, 2004 | 07:31 PM
SBV45's Avatar
SBV45
Gregomayer,
What did the dealer do for maintenance? What sensor did he replace? While mileage can be all over the map for a bunch of reasons, 11 mpg unloaded does seem pretty low. Have you done any mods like tires, lift kits, etc to your truck?
Old Dec 18, 2004 | 07:54 PM
kw5413's Avatar
kw5413
How much oil are you draining and how much oil are you putting back in?
Where is the oil fill line in regards to your dip stick?
