Where does this stud bolt go? HELP!!
The two long ones hold the AC/power steering pump bracket on. I did that. But the third, shortest one, I have no idea. It has corrosion in the middle and obviously went through the water pump, but all those appear accounted for. Nothing needs a stud bolt, but from the look of the grime on the outer threads maybe nothing was ever threaded onto it in the first place.
I have one bolt hole of this diameter on the bottom of the timing cover of the same diameter, but a stud cannot go here, it would jab the water pump inlet hose.
