what year is best?
Old Dec 17, 2004 | 09:05 AM
castironmeyer's Avatar
castironmeyer
what year is best?
I want to put a 300/6 in my 89 F350. Is one year better than another? I do not want the EFI. Any advice would be greatly appreicated!
Old Dec 17, 2004 | 01:31 PM
85e150's Avatar
85e150
Too bad you don't like EFI, as those were the best years.
Try 85 or 86 might be ok, or 82 and earlier. Some mid 80s really loosened their exhaust manifolds possibly due to higher operating temps for emissions--not really sure. My 85 loosens the manifold too, but it seems like the 84s were the worst.
Old Dec 17, 2004 | 08:04 PM
castironmeyer
It's not that I don't like the EFI, I thought it might be harder to install. The truck recieving the motor has a 351 V8
Old Dec 17, 2004 | 09:04 PM
74F250's Avatar
74F250
best setup would be 95-95 when they had MAF EFI. I wouldn't bother with late 80's unless you swap back to the dsII setup as the elctronic carb is a bitch
Old Dec 18, 2004 | 12:02 AM
Col Flashman's Avatar
Col Flashman
'66 t0 '72 series 300 I-6's are the unbeatable, simple & has the Best overall performace.
Old Dec 18, 2004 | 12:38 AM
85e150's Avatar
85e150
Also, in the '80s they used TFI ignition. Ditch that if you find it. It is prone to sudden failure, usually when you are in front of a train or on a drawbridge that is signaling to open.
Old Dec 18, 2004 | 12:42 AM
85e150's Avatar
85e150
Consider this: You may find a roll, bad crash or partial burn low mile job with the efi motor. (someone's misfortune is your gain) Buy the whole thing and swap all the stuff. (easier said than done, I know). You may be able to find a rolling total in the want ads that some guy wants to unload.
Are you planning on doing any kind of rebuild on the 6 before you install?
BTW, if you are going with the 300 to save gas over the 351, think again....
Old Dec 18, 2004 | 08:01 PM
castironmeyer
Yes, I am planning on a total rebuild before installing. The EFI might be nice. I just bought a 89 crew cab that has a 351 with a 5 speed. the P/O installed the motor and trans. the truck originaly had a 460/auto I have never had good luck with any V8 and the I6 seem to run for ever (IMO). the truck will be used for work.
Old Dec 19, 2004 | 11:41 AM
fordinlinesix's Avatar
fordinlinesix
Get a 300 HD or 240 block =). If you can find a '60's motor that hasn't been bored or trashed, it would be better, they were thickwall designed and were able to be bored out .060 over with no problems. I got a 247 now =)
Old Dec 23, 2004 | 01:17 PM
Schmids4.9l's Avatar
Schmids4.9l
I would drop a 7.3 diesel into a 1 ton, but i guess you should go with efi 87 and later.
Old Dec 23, 2004 | 01:24 PM
optikal illushun's Avatar
optikal illushun
for a crew cab, which means F-250 or 35o go with something with more grunt.
also, if u were to go with a 96 EFI u would have ODB-2 and thats to much work and hassle.
