resonator do i need it
Old Dec 17, 2004 | 12:19 AM
blue96psd's Avatar
blue96psd
he yguys i am puting in a custom exhaust 4in to 5 in stacks on ym truck now i got a cat and a muffler should i jsut can those and get the resonator also i am putting a 4in dp does this sound alrite ???
Old Dec 17, 2004 | 05:00 AM
blackf3504dr's Avatar
blackf3504dr
Personaly , I don't think you need any of those three items . Good luck getting a 4" DP in there ! You may want to consider a 3" or 3.5 " DP that bells out to 4" , even then you will need to flatten out the pinch weld on the body seam to get it to fit . How about some pics when you get her done ?
Old Dec 17, 2004 | 10:36 AM
Max1775's Avatar
Max1775
I have to agree with black, I don't think your going to get a 4" DP in there unless you have a body lift on the truck or use a porta-power to bend the hell out of the firewall which I would not recommend. I had to put new polyurethane cab bushings on my truck to replace the worn out stock rubber ones just to keep my 3.5" DP from rubbing.
Max
