removing emblems
Old Dec 16, 2004 | 02:12 PM
tbrewer333's Avatar
tbrewer333
removing emblems
i was wondering if i remove the emblems off my 2000 year model, will it require i get a new paintjob, and if so how much will that cost?
Old Dec 16, 2004 | 06:38 PM
Pirate16's Avatar
Pirate16
i am not sure if you would need a new paintjob but the paint under the emblems would not be as faded as the rest of the paint.
Old Dec 16, 2004 | 06:49 PM
triton_2002's Avatar
triton_2002
Yeah, you might have a fading problem, depending on the color and sun exposure. Some of the badges also have alignment holes, so you would need to fill those. If you do take them off, try using a piece of fishing line and work it back and forth under the badge to saw off the mounting tape, then you can clean up the residue with adhesive remover.
Old Dec 16, 2004 | 06:59 PM
"Beemer Nut"'s Avatar
"Beemer Nut"
Emblem removal
To remove stick on emblems i have used a heat gun to soften the adhesive backing. Not those 1,000 degree job or you'll burn the paint. Carl....=o&o>....
