heeeellllpppp
Old Dec 15, 2004 | 08:17 PM
straight6beast's Avatar
straight6beast
heeeellllpppp
recently replaced plugs wires dis cap and rotor now my truck dont fire
get somke and she rollls and sounds like she wants to fire (get the occasional mild fire) but doesnt catch
pretty sure i lined everything up they way it was supposed to go even doubled checked the fireing orders any suggestions? please
88 f150 4.9L
Old Dec 15, 2004 | 08:48 PM
DT 466Man's Avatar
DT 466Man
Double check to make sure you didn't cross the wires or put the cap on backwards after you might of attached the wires before you put the cap back on
Old Dec 15, 2004 | 09:42 PM
beez82gt's Avatar
beez82gt
check the distributor, ensure it wasn't moved. timing? is spark plug gap set properly. might be the problem. good luck.
Old Dec 15, 2004 | 11:40 PM
GregTruck's Avatar
GregTruck
Words to live by. My 65 had all the wires shifted like 3 towers back. The friendly #1 marking on the cap could be very misleading. If nothing else works set your #1 to TDC-compression stroke and look where your rotor is pointing in reference to the cap and wire #.
Greg
Old Dec 16, 2004 | 08:45 AM
wickymustang's Avatar
wickymustang
Double check that the cap isn't flipped 180 from how it should be. Had to redo my cousins cap because he put it on backwards. Took and it turned it 180 degrees and it fired off no problem. And he had all the same symptoms as you described.
Old Dec 18, 2004 | 11:59 PM
straight6beast
thnx guys
thnx guys got 'er fixed tonight she runs like a charm when i put the dist back in she went in 4 teeth past where she was supposed to go clockwise just gotta figure out how to re hook up the smog pump next
Old Jan 2, 2005 | 09:51 PM
HOT WLZ's Avatar
HOT WLZ
Just leave the stinkin' smog pump off. Who needs it? Unless you live in CA that is.
