trailer wiring question
Old Dec 15, 2004 | 02:19 PM
CJS51's Avatar
CJS51
I recently traded my 03 scab (w/ towing package) for an 04 screw (w/ towing package) and purchased a Prodigy brake controller for the 04. When I hook-up to my horse trailer, the interior trailer lights and loading lights don't work. All other lights work. Is there a connection I missed?
Old Dec 15, 2004 | 05:09 PM
Steina's Avatar
Steina
CO River Rat
Did the trailer interior/loading lights work OK when hooked up to the '03? If so, did the truck have to be running for the lights to work?
Steve
Old Dec 15, 2004 | 08:37 PM
05F250Fan's Avatar
05F250Fan
The 7 pin round connector has an AUX pin. This can be used for backup lights on the trailer; rarely used, or for other things like lighting in the trailer. You might check to see if the center pin is hot when you need it.
Old Dec 16, 2004 | 11:26 AM
CJS51's Avatar
CJS51
Steina - yes, the lights worked with the 03 but I did not install the brake controller and the truck didn't need to be running for the lights to work. I think 05F250Fan is probably correct that the aux pin is not hot. Thanks
05Fan - If the aux pin is not hot, is there much to making the connection? My experience with electric is basically changing a light bulb. Thanks
Chuck
Old Dec 16, 2004 | 12:19 PM
Cowboy Brett's Avatar
Cowboy Brett
There is a 12V "Battery Charge" Pin that is hot only when the key is on for 04s. It'll be denoted by "+" on the diagram.
There is actually a mini-diagram of what all the pins do that is cast right onto the flip-up cover if you've got the same factory one that's on my 04 F350 with the Tow package.
Old Dec 16, 2004 | 05:27 PM
Steina's Avatar
Steina
CO River Rat
CJS51 -
Normally, no pin is hot on a 7-pin connector when the key & lights are off; I'm not sure how your '03 was wired to run the trailer's interior/loading lights without the key/engine being on. You need to check the trailer's 7-pin connector to see what pin powers those lights. Do the electric brakes work OK, now that you've installed the Prodigy? The "Aux" (center) pin is hot only when the key is on and gear selector is in Reverse.
Steve
Old Dec 23, 2004 | 12:11 AM
clstrfbc's Avatar
clstrfbc
The seven pins should be, clockwise from top
Aux power - to charge breakaway battery,
right turn
Elec brakes
ground
left turn
Tail/running
backup - Center
(brake lights consist of lt and rt together)
You might have blown your aux power fuse. My '96 has seperate fuses for the trlr aux, trlr backup, and trlr lights in the engine fuse box. My truck didn't have a fuse installed for trailer lights the first time I tried to use it. Have you checked your owners manual for fuses or relays.
Old Dec 23, 2004 | 07:57 PM
stewcon's Avatar
stewcon
On my 05 no pins are hot unless the ignition is on. The center pin only with the truck in reverse. On my last truck (98 Chev) the center pin was hot all the time. This was nice for my inside trailer lights. I am currently thinking of changing my 05 F250 to be the same way.
Old Dec 24, 2004 | 03:58 AM
Kaleo's Avatar
Kaleo
None of the pins should be hot without the key or lights on. If you got the truck used, then the PO may have wired it different.
I would concider adding a batt to the trailer. Run the lights off that and charge with AUX power pin as opposed to wiring the truck for a constant hot lead. Then you could use those lights when ever and not worry about things like:
Having truck hooked to trailer.
Accidently locking keys in truck.
Killing the main batteries in truck.
Just a thought you might be interested in.
Old Dec 28, 2004 | 07:47 PM
Steina's Avatar
Steina
CO River Rat
CJS51 -
Did you ever get those trailer lights figured out?
Steve
Old Dec 28, 2004 | 09:15 PM
grafekie's Avatar
grafekie
try turning on the headlights... many trailers use the running light lead to power interier lights. Good luck with the exterier ones, I have never seen or used a horse trailer with exterier lights that worked, and I tow/work around LOTS.
Old Dec 29, 2004 | 11:00 AM
CJS51's Avatar
CJS51
Sorry for the delay. With holiday's & winter storm I haven't had a chance to look into it yet. Probably will this weekend and will post any results. Thanks and Happy Holidays
PS. 1)Tried the lights with the headlights on, didn't work 2) only exterior trailer lights work with the ignition off, but the head lights on
Old Dec 29, 2004 | 11:13 AM
grafekie's Avatar
grafekie
this may sound stupid, but is there a switch on the internal light? All my horse trailers have a little push button on it...
Old Dec 29, 2004 | 12:01 PM
CJS51's Avatar
CJS51
Thanks for the thought grafekie. Yes all the internal lights (and the loading lights) are switched. I even checked the bulbs to ensure they didn't all blow! I'll have it figured out this weekend (hopefully).
Thanks
Chuck
Old Dec 30, 2004 | 03:50 PM
stewcon's Avatar
stewcon
I like the idea of a battery in the trailer to run my inside trailer lights. My question would be, if i wire the battery to the terminal box on the trailer (so my inside lights would be fused) the terminal on the truck plug looks to be the one mark + (battery charge I think) would this damage anything if I left the truck plug into the trailer when using the inside trailer lights? I sure don't want to damage anything on my new 05 SD. Any information would be nice.
Thanks
