CB Radio
Old Jan 3, 2005 | 11:56 PM
fixnair's Avatar
fixnair
I don't run my truck thru a carwash as it has DRW. I have broken a couple of flourescent lamps at Mc Donalds though.
Old Jan 4, 2005 | 07:22 AM
Hjudge49's Avatar
Hjudge49
I used to have a 9 foot steel whip mounted on the tool box on my Z71. I ruined several flouresent lights and killed at least 2 pidgeons and one big white heron with it.
Old Jan 6, 2005 | 04:41 PM
Fire Rooster's Avatar
Fire Rooster
Well I finally got it done. I paid someone to help me out I got rid of the firestiks and went with a Wilson 1000, the installer drilled a hole through my roof and mounted it for me. Checked the SWR and I am at 1.2 or less throughout the range 1-40 channels. It works well only, for some reason I gotta have the sqelch pretty high, I get a lot of noise if I don't. Thanks for all the help guys!!!
Old Jan 6, 2005 | 07:47 PM
DeerSniper's Avatar
DeerSniper
Hey fixnair where do i get one of those amplifiers from?
BTW, I've got a Cobra Classic 29 w/ a Wilson 5000. I've got the CB under the middle seat with just the front showing. I've got the 5000 in the bed behind the toolbox w/ just a little of the black ball showing. I had it on the roof w/ a mag. mount, but i got tired of that look. Also, ant. came off chipped paint to the primer on my door.
I ran the cable through the grommet in the bed, through grommet and carpet under rear floor mat, up under middle seat.
Old Jan 7, 2005 | 12:08 AM
fixnair's Avatar
fixnair
DeerSniper, I bought mine from a friend and I don't know where he got it. I think someone gave it to him. You should be able to buy one at a CB shop at a truck stop probably. Good luck withit.
Old Jan 8, 2005 | 06:44 AM
missouguy's Avatar
missouguy
I use the mag mount as well. I have the whole radio and antenna on temp rigs so I just put it in when I am traveling. The rest of the time it is in the garage.
One little tip on the mag mount, cut a piece of thin felt in a circle a little bigger than the mount and put it on then the mount. It won't effect the grip, and it won't scratch the top.
Frank
Old Jan 8, 2005 | 12:32 PM
StrokedRanchero's Avatar
StrokedRanchero
I'm a newbie with 2cents to add,I bought a glass mount cell phone looking ant. from JC Whittney and mounted it on my backglass, it looked cool and inconspicious but didn't transmit for crap. I ended up buying a mirror mount bracket from a truck stop and mounted my ant. on my righthand tow mirror and ran the coax through the door opening and behind the kickpanel.
Old Jan 8, 2005 | 02:09 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
Welcome to Ford Truck Enthusiasts! If you have a minute check out the Guidelines, it will help you to navigate through and understand FTE.
Enjoy FTE …..
Old Jan 17, 2005 | 05:31 AM
purplewg's Avatar
purplewg
For future reference, there is a grommet right below the go pedal. If you use the ball mount for the antenna you need to cut off the end of the cable anyway as it connects direct to the wires. I used a punch, put a little hole in it and just pushed the cable through it. I also have my wiring for the electric fuel pump in the back running though it. Makes a reall good seal. If you need the screw on connector to attach to the antenna then you need to use one of the grommets in floor under the seats.
Old Jan 17, 2005 | 11:08 AM
EJL96PSD's Avatar
EJL96PSD
While we are on the CB topic, does anyone have any tricks for getting rid of alternator noise? I have tried different places for grounding and power. Still have the wine. I am however getting a good idea of engine speed without looking at the tach when I have the CB on, hehe.
Old Jan 18, 2005 | 11:33 PM
missouguy's Avatar
missouguy
I think there is a capacitor that you can put on your alternator to eliminate the whine. You might check with RadioShack.
Frank
Old Jan 19, 2005 | 09:29 AM
EJL96PSD's Avatar
EJL96PSD
Sweeet! Thanks I'll check it out
Old Jan 19, 2005 | 09:36 AM
  #28
Hjudge49's Avatar
Hjudge49
I went ahead and installed a K40 roof mount and a vhf antenna roof mount at the same time. Just removed the dome light assemblies, drilled the holes from above (using an old screwdriver as a spacer between the metal and the headliner and fished the coax to the drivers side a post and down behind the weatherstriping. I ran my power leads thru the firewall access hole and connected directly to the battery. Seems to work pretty good, I just get some wind whistle from the antennas.
Old Jan 19, 2005 | 09:45 AM
  #29
barebackjake's Avatar
barebackjake
hey fire how are thoose wilson antennas working for ya? did you get the flexible fiberglass or the regular ones? did you go duals?
Old Jan 19, 2005 | 02:43 PM
  #30
Fire Rooster
It works great thanks for the tip. I went with a single roof mount wilson 1000, I broke down and drilled a hole in my roof. I am happy with it, except , now at freeway speeds I hear a whistle from the antenna. No biggy.
Fire Rooster
