Sponsored by: Real Truck
'99 SD heater problems
Old Dec 15, 2004 | 01:15 PM
jtf55's Avatar
jtf55
Helo, New to site. I have a '99 SD F-250 7.3d. The heater blows cold and the temp gauge is in the right range. I turned the temp control back and forth several times and it started blowing warm, but only for two to three min. then back to cold. The cooling system was serviced this year with thermo replacement. Any help would be much appreciated. Thanks J.T.
Old Dec 15, 2004 | 01:28 PM
Fordlover55's Avatar
Fordlover55
Still kicking!!
Welcome to the site.
Please make sure to read the forum guidelines and the READ FIRST notes in each forum you visit. If you scan the forum listings, you'll see we have topics that will match your vehicle and interests.
Old Dec 15, 2004 | 02:29 PM
99f350sd's Avatar
99f350sd
The heater control is a potentiometer the heater blend door is controlled by it. The blend door has a motor control on it. Behind the glove box. Sometimes the motor control goes bad. Its not bad to get out.
Dick
Old Dec 15, 2004 | 02:57 PM
slc10844's Avatar
slc10844
Someone had a problem awhile back with no heat. Turned out to be a pen fell in the heater box, I guess through the defroster, and kept the blend door from working properly.
Old Jan 7, 2005 | 09:20 PM
Dave Lyon's Avatar
Dave Lyon
Hey jtf55,
Did you ever resolve your heater issues? I also have a 99 F250SDPS7.3 and am having the same problem. I checked for obstructions and non found. So I am at a lose as well.
Dave
Old Jan 8, 2005 | 11:32 AM
jtf55's Avatar
jtf55
Thumbs up '99 SD Heater problem
Yes, I think I found the problem. The plug to the vacuum pump was loose. I unpluged it and cleaned the conection and every thing is working great. Good luck with yours.
