04 power stroke. cold idle...
i have a remote starter installed in my truck and when i start it in the morning, my truck seems to idle a lilltle higher than normal. when i step on the brake or gas pedal the idle drops back down. if i let it idle a little while, it'll go back up. this seems to stop once ive been driving around a little and the engine warms up. is this normal?
Last edited by south bay 6.0; Dec 15, 2004 at 02:03 AM. Reason: forgot to add year of truck.
This is normal. I can't explain all the technical details but it is to help with engine warm-up.
As a aside, can anybody tell me why the 6.0 only idle up to 900rpm and the old 7.3 went up to 1200 or more when going through this cycle?
Tim ------->>
Tim ------->>
Be sure to check out the 6.0 Bible…..great reading
http://dan.prxy.org/Truck/6L_bible_html/html/TOC.html
http://www.backglass.org/duncan/ps60_manual/
…. In the upper right hand corner of your screen check this out PARTS SHOP for all your “trucking” needs
Must read
http://www.clubfte.com/users/monsta/SuperDutyFAQ.html
https://www.ford-trucks.com/forums/s...d.php?t=303583
Enjoy FTE
Welcome to both you New guys !!!!!!!!!!
Your're right, normal after a few minutes of idle for it to pick up the pace - just for warming...
Many theories out there why... but it just does it !
And the 7.3 and 6-oh are MUCH different in a lot of respects... maybe the 6.0 doesn't HAVE to idle up as much as the 7.3 did - actually not something I'd ever noticed on the 02 7.3 I had...
