Bad U-Joint?
Old Dec 14, 2004 | 08:55 PM
79 posi's Avatar
79 posi
Bad U-Joint?
I've got a 92 f-150 2wd that is starting to get an intermittant vibration. not much in 1st and 2nd, although, more when accelerating. progressively getting louder.
The u-joint right behind the carrier bearing (or whatever the rubber surrounded joint is called) looks bad. I can wiggle it pretty good and can see that the rubber around a couple of the end caps is shot.
Is this causing my vibration?
Thanks
Old Dec 15, 2004 | 12:17 AM
sixpack2639's Avatar
sixpack2639
Probably is. IMO Best thing to do is replace all 3 joints and the carrier bearing if 1 is bad. That is what I do. Carl
