Swaping ECMs
Old Dec 14, 2004 | 06:42 PM
fordfan94's Avatar
fordfan94
Swaping ECMs
I have eletrical EGR problems with a 86 2.9. I was not able to solve the problem so I switched to a 89 engine control module the engine now runs fine. Because this unit the EGR system. Transmission also shift fine. Have driven about 200 mile with this set up. Does anybody think I will hurt anything using this ECM. What sensors might be a problem in the EGR system.
Old Dec 14, 2004 | 07:37 PM
Ken00's Avatar
Ken00
The 86 also had a knock sensor so that won't function and you may get a tranny code, the 89 had the converter clutch solenoid and the 3-4 shift controled by the ECU and I think the 86 only had the ECU controling one of them.
Old Dec 15, 2004 | 06:03 AM
fordfan94's Avatar
fordfan94
Thank you very much for reply. Knock sensor will not be a problem. And the 3-4 shift is a working fine shift around the same speeds it always did. Thanks fo help.
