Block Heater??????
Old Dec 14, 2004 | 03:59 PM
dsldandually's Avatar
dsldandually
Block Heater??????
Ok guys what kinda block heaters do you reccomend?
1. soft plug (freeze plug)
2. tank recirc.
3. bottom rad. hose
my stock one has bought the farm after tracking down a cord from the stealership to find out it doesnt work any more. really ****ed me off!!!!
Old Dec 14, 2004 | 04:38 PM
pnose's Avatar
pnose
I would go back to oem,but thats just me.It seems to be a proven method.
Old Dec 14, 2004 | 04:42 PM
RR4E's Avatar
RR4E
I've had good luck with the recirculating pump style heaters. The lower rad hose heaters work ok, but like stock block heaters, only really heat a localized area, where the recirc unit heats, and pumps warm coolant throughout the engine, and if you leave it on defrost, will usually keep the windshield clear as well. The added bonus, the truck will likely have relatively instant heat on cold days, reduced idle/warm up time, and in the long run, that saves fuel and wear and tear.
Old Dec 14, 2004 | 06:49 PM
dsldandually
RR4E,
Ok thanks now for the next million dollar question how do these install I bought a Katz and it didnt look like it would work due to space constraints and maybe a little stupidity on my part. Do you need to tap into the block drain then into a heater hose or do these things just go in the heater hoses.
Thanks
Old Dec 14, 2004 | 11:03 PM
PLC7.3's Avatar
PLC7.3
Ensure you read the instructions re the KATZ really close, 1SG tried installing one of those recirculating type recently and burned his up. Due to the fact it must be placed at the lowest level, well we have no heater hoses down that far on the engine. He has a BH back in there now........seems happy.
Old Dec 22, 2004 | 07:50 AM
rickkk's Avatar
rickkk
Had the same prob. After long search ended up at Napa,they can order any type,cord will come with. Rick G
