Ssm 17646
MESSAGE TITLE: 2004 F-150 - MIL ON WITH DTC P2106
APPLICABLE VEHICLES :
2004 TRUCK : 00029 F-SERIES LD
OASIS MESSAGE :
SOME 2004 F-150 VEHICLES BUILT BEFORE 3/25/2004 MAY EXHIBIT THE MALFUNCTION
INDICATOR LAMP (MIL) AND ELECTRONIC THROTTLE CONTROL (WRENCH) LIGHT ON WITH
DIAGNOSTIC TROUBLE CODE (DTC) P2106, WITH OR WITHOUT OTHER DTC'S. TO SERVICE,
FIRST RECORD ALL DTC'S AND SERVICE DTC'S STARTING WITH 'C' OR 'U' (DO NOT
SERVICE DTC'S STARTING WITH 'P' PRIOR TO REPROGRAMMING). NEXT, REPROGRAM THE
PCM TO THE LATEST CALIBRATION LEVEL USING WDS RELEASE 30.4 OR HIGHER.
CALIBRATION FILES ARE ALSO AVAILABLE AT WWW.MOTORCRAFT.COM. IF DTC'S REAPPEAR
AFTER REPROGRAMMING, SERVICE AS DIRECTED BY THE WORKSHOP AND PC/ED MANUALS.
NOTE: DURING REPROGRAMMING, IF PROMPTED TO ENTER THE VEHICLE IDENTIFICATION
NUMBER (VIN), BE SURE TO ENTER THE CORRECT VIN NUMBER. FAILURE TO DO SO WILL
RESULT IN DTC B2900 IN THE ABS MODULE.
APPLICABLE SYMPTOM CODES :
B2900 VIN MISMATCH
P2106 THROTTLE ACTUATOR CONTROL SYSTEM - FORCED LIMITED POWER
206000 ELECTRICAL WARNING INDICATORS
608000 DRIVEABILITY RUNS ROUGH
608600 DRIVEABILITY RUNS ROUGH - CRUISE
609000 DRIVEABILITY MISSES
610000 DRIVEABILITY BUCK/JERK
611000 DRIVEABILITY HESITATION/STUMBLE
614000 DRIVEABILITY LACK/LOSS OF POWER
614500 DRIVEABILITY LACK/LOSS OF POWER - ACCELERATION
614600 DRIVEABILITY LACK/LOSS OF POWER - CRUISE
698298 DRIVEABILITY MALFUNCTION INDICATOR LAMP - MIL
